With everything else I've planned, I've decided to build a server that would mainly be for video storage and streaming to other devices (it will also be for data storage as one of many backups).
The question about using either new or old parts is that I have an asrock 775i65G R2.0 (just to be clear since there are two variants of that board) that I purchased ages ago for my desktop upgrade and hadn't used (it's still in it's bag in the box with everything else), but I'm not sure if I should use it for this project for the following reasons.
While I can get a compatible CPU for next to nothing, the RAM is going to be at least twice as much for 1GB then I would pay for 2GB or 4GB of low end DDR3 RAM plus I would be limited in what I can get in regards to hard drives along with size and quantity since I can't seem to find anywhere that sells IDE cables which would allow the use of the second IDE connector (and I would most likely be on the eternal lookout for compatible SATA hard drives since I doubt that current drives would be compatible with the older SATA ports on the board) and there's the issue of if the board itself still works.
On the other hand, I could build a system with an AMD socket FS1b (AM1 chipset) motherboard, processor, RAM, SSD for the OS (it wouldn't need to be that big since I'll be using linux for this), a starter HDD for storage and anything else I haven't mentioned here (like the case and power supply which I'm guessing wouldn't need to be that powerful) for around £250 and then add a SATA controller card to connect further hard drives in the future (this is just an example, and not a final spec).
I haven't decided on what variant of linux I'll be using for this, but I have a few images downloaded to experiment (although that is a problem at the moment since the only way I'm experimenting is through a virtual machine and I'm having a few issues with it) to nail down what I'll be using.
So, having read all this, should I try using the old board or should I just use new components so I can guarantee compatibility.
