TITAN sli vs 980ti
9 Nov 2009
The Shire
Hi
Does anybody have any stats on the above comparison. I've currently got a evga titan and wondered if i'd benefit massively from getting another and sli'ing or whether id be better of getting a single 980ti?
Id like to be able to run all of my games at Ultra 2650x1440 resolution and the titan struggles to do this on occasion..
Thanks
A factory OC model 980Ti should be just as fast as Titan SLI, especially in modern games as the Kepler cards struggle a bit with optimisation. Single high end card is usually the best way to go.
980Ti.
You'll get better performance, avoid SLI issues and get rid of an old card.
https://tpucdn.com/reviews/MSI/GTX_980_Ti_Lightning/images/perfrel_2560_1440.png[IMG]
Take the 780ti for reference, even faster than your Titan.
(I do consider the Lightning the baseline as that's a clock any 980Ti can reach. Factor in the SLI scaling and you get the double performance).
[COLOR="Yellow"]**No hotlinking please**[/COLOR]
If you check around Titans are being sold for 300£, which is quite ridicolous considering you can get a 970 for less.
Guess it's an iconic card.
Don't forget OG TITAN swag.
It's the only reason I haven't upgraded. I wish I was joking...
People often get the idea of buying a high end card today and another in a long time for an easy upgrade, but it's rarely worth it as a single future card would be a better choice.
IMHO SLi/Xfire is only worth bothering with if you are doing it with two recent high end cards.
Sell the titan and get a 980ti.
You could do it for less than £160.
Which makes me wonder why the hell I'm not doing it.
