- 24 Mar 2011
- Cambridgeshire
You get the same increase in power usage if you plug in more than two monitors.
On AMD cards, you used to get the same thing with only two connected. Idle power consumption of the GPU would go from ~15 to 50+ watts. They did that for years and years, even as recently as the R9 290's. I haven't bothered to check if the 380's based on the same designed are still as utterly crap on idle, though I did hear the fury's had finally stopped doing it. Shame it took them so long to bother doing anything about it.
