Watercooling on budgets, where do you source used parts?
The members market here is good but unfortunately you're a long way off access.
I think ebay and gumtree are about the only other places I would personally use myself so unfortunately I cant be much help : (
Check the watercooling clearance section on the site regularly,loads of great bargains in their on a pretty consisitant basis :D
Not sure I'd want a used item in a water cooling loop. Tough to tell the state of the insides unless it has a clear top.
Nox
Nox
It's very easy to tell the state, run water through it. If it stays clear then it's fine.
Unless it's an really old part then it's very likely that it'll be fine as people now use specific parts for water cooling PCs like mayhems fluid, anti leeching tubing and no aluminium.
Be aware that the watercooling section if clearance isn't necessarily all of the watercooling stuff. Some things haven't been categorised.
