Trying to compress pics enough for Autotrader...
29 Jul 2013
I'm trying to compress some files to under 150kb (autotrader limit), but lightroom won't compress them to anything under 700 or so kb. They are files from a 5D classic so not huge files (10mb ish each).
How can I possibly get them to be smaller files?
Help!
Thank you for any advice :)
File -> export -> image size
Don't personally use lightroom, but that is what I could find by googling.
Paint.net is my goto for quick image manipulations
It's already been said but you can do what you want when exporting from Lightroom.
One of the options is to specify a max image size or you can pick how large (pixel size) you want the image exported instead and have it export it out like that. There's no need to use any other application.
I've tried that, but it says failed as 150k is too small apparently
