8 Nov 2015 at 21:53 #21 AHarvey AHarvey Soldato Joined 6 Mar 2008 Posts 10,094 Location Stoke area export at a low resolution and upload to dropbox, share the links here and i'll do them later in photoshop.
8 Nov 2015 at 21:56 #22 Zefan Zefan Man of Honour Joined 15 Jan 2006 Posts 32,901 Location Tosche Station Use irfanview. It is great.
8 Nov 2015 at 22:03 #23 Cleisthenes Cleisthenes Soldato OP Joined 29 Jul 2013 Posts 8,689 AHarvey said: export at a low resolution and upload to dropbox, share the links here and i'll do them later in photoshop. Click to expand... Doing it now. I hope 2mp will be sufficiently low!
8 Nov 2015 at 22:03 #24 Cleisthenes Cleisthenes Soldato OP Joined 29 Jul 2013 Posts 8,689 Zefan said: Use irfanview. It is great. Click to expand... Not available for mac unfortunately
8 Nov 2015 at 22:07 #25 Cleisthenes Cleisthenes Soldato OP Joined 29 Jul 2013 Posts 8,689 AHarvey said: export at a low resolution and upload to dropbox, share the links here and i'll do them later in photoshop. Click to expand... This should work... My internet is too shokcking to load the link e: Yep, that worked. Thanks in advance AHarvey Last edited: 8 Nov 2015
8 Nov 2015 at 22:10 #26 Phal Phal Soldato Joined 19 Jul 2004 Posts 4,087 Location Shoreham by Sea You're right in saying it doesn't seem to like having a file size limit of 150KB but I tried something different I changed the export options to 1280 longest edge, 120 pixels per inch and the file size limit of 150KB works.
8 Nov 2015 at 22:10 #27 Cleisthenes Cleisthenes Soldato OP Joined 29 Jul 2013 Posts 8,689 Phal said: You're right in saying it doesn't seem to like having a file size limit of 150KB but I tried something different I changed the export options to 1280 longest edge, 120 pixels per inch and the file size limit of 150KB works. Click to expand... Ah, I shall try that now. Thanks.
8 Nov 2015 at 22:12 #28 Cleisthenes Cleisthenes Soldato OP Joined 29 Jul 2013 Posts 8,689 Cleisthenes said: Ah, I shall try that now. Thanks. Click to expand... Ah ha!! It worked! Thank you Phal, you the man
