Hey all,
Some of you may remember my first water cooled build from a couple of years ago, I got a lot of help from this forum.
Been really happy with the build its be faultless and always consistent temps.
It's been untouched for almost 2 years now and I'm thinking it could do with a fluid refresh and dust out, then I thought while I'm at it I'd like to give it a new look so am thinking of changing over to acrylic tubing.
Current tubing is 16mm OD and I was thinking of changing to 12mm acrylic for looks but also cost saving as it seems 16mm fittings are much more expensive.
Question is what sort of difference in temps would I get changing to 12mm tube?
Also am I right in saying I'd just need these adapters for the majority of the build, rads, water blocks etc?
cheers.
cheers.
