It does have a deeper recess along the bottom. And I have tucked my drainage tube there so you should be good.
You can fit atleast two Samsung evo ssds on top of each other if that helps
What size tubing? It should fit fine. It is 26.5mm at the top and 37.5mm at the bottom. Hope this helps.
