Can anyone recommend an infra-red camera thingy that can be coupled with an iPhone app?
Not to be grim but if he's stopped breathing/moving...isn't it a bit too late?
That looks excellent. How is streaming over 3G/4G? Can the camera be angled downward? Are the LEDs on the front bright? I was hoping it would be discrete as he's old enough now to notice it and I reckon it would keep him awake pointed right at him.
We used to have a simple walkie talkie one, now (20mths old) we just listen out for him as he makes enough noise if he wants something or needs help re-settling, but for number two I might consider the sensor pads if they don't give off too many false alarms, as I'm sure each alarm will cause us a micro heart attack!
First child we had baby monitors, second, wine.
I would highly recommend you DON'T get one of those sensor pads.
You'll have the baby next to you for the first few months anyway and no doubt any snuffle or noise will have you leaping out of bed anyway but many friends of ours had horrible experiences with those pad-based monitors.
One in particular had a baby that used to (somehow) move around the cot quite a bit and several times in the night the alarm would go off and they'd leap out of bed thinking their baby had stopped breathing - I swear the dad went grey after a week! They literally threw theirs our after a month.
We got one of the Motorola ones with a camera. I wasn't really fussed about having one but the missus wanted it so I caved, £45 we paid as it was on offer on Amazon at half price and they did an Amazon family promotion for a further £15 off.
To be fair it's been really good, there are times in the night that Elsie will cry in her sleep and settle off again 30 seconds later, or when she's babbling in the morning but just pacifying herself, it's saved us jumping out of bed as much as we might have otherwise. I'd definitely recommend it.
There are a couple of threads on here fairly recently about baby monitors and new baby essentials if you have a search.
Also congratulations mate![]()
I disagree here
Our sensor pad and monitor works fine, once in a blue moon it does go off incorrectly and usually the result of the angle the baby is now sleeping at (my little one is 5 months old now).
Well worth the re-assurance, especially when he was young. Yes we did have a couple of jump out of bed moments but I'm being honest when I say it was once or twice maximum.
We use the AngelCare AC401, acts as a monitor plus the pad, both of which can be switched on/off, with beeps for movement or not (shows on monitor), room temperature etc.
All in all, I recommend one, just follow the guidance - centre of bed, do the tests, on a firm wood base etc.
Hi,
Wireless ip camera as others have said. Handy check on your baby without going in as not to disrupt them, has audio and intercom. Night vision works great, and ideal over wifi or 3g and above.
www.amazon.co.uk/dp/B00R49X41C/ref=pe_385721_37986871_TE_item
Never used one, unless you live in a huge house and cannot hear from where you sit in the evenings.
Waste of money, paranoia creating machines![]()
