just make sure you take it from a couple of metres back to avoid capturing IPS glow. on a slowish shutter speed should help capture it more realistically. also make sure you are at a sensible recommended brightness level (not 100% )
No I want to see the glow. Glow is worse than BLB.
Some edge bleeding isnt a big deal, huge splotch of glow is.
An entire movie or game can be ruined by Glow.
I agree with badass, ive looked at some dark videos like batman and like he said it all depends on viewing angles and distance, I found the film will look fine with no glow but turn my chair to the left a bit and tilt my head and you can make the glow look quite bad and vice versa
again if you look at chippers pic on page 30 you will see some yellowing in the left hand corners which is the same as my glow, but for some reason cameras pick it up much worse than it actually is, I will try a film later when its dark and see what its like then
glow is massively subjective and individual, depending on your viewing position, viewing distance, angle of tilt, ambient light etc. you could take a picture of any modern IPS screen pretty much and make it look truly awful from a glow perspective if you wanted, so i'm not really sure what these photos will show.
And all it will do is scare the uninformed or browsing reader in to thinking its backlight bleed when it isn't. You see it all the time with people labelling it as a quality issue when a lot of the time it's just a bad photo done wrongly and capturing lots of glow
The Dell U3415W I sent back had bleed on the left hand side should I just put this down to bad luck and order another? Or are the Dells prone this and the Acers not? If so I will order the Acer. I basically want an ultrawide with no Bleed.
Your asking for too much
All I can say is I'm happy with my Acer and if people are sat on the fence whether to buy it or not then just get one and if you don't like it just send it back simples
Do you play anything dark at all?
And I wouldnt get one with the issues they currently have.
Thats ******** and you know it.
Everyone is going to be bothered playing a game like Alien Isolation when half the screen is covered in a silver/yellow/orange/blue sheen and the other half is black.
Its not "subjective"
I want a photo (video screengrab which doesnt exaggerate anything) taken at a normal distance from a normal sitting angle. I doubt many people sit with their faces glued onto their displays or 3m back. The average person sit about an armlength from their monitor.
And Baddass, please come out in the reality, IPS Glow is a problem, its not subjective. Not everyone gets cherrypicked units or sit 3m back.
What these photos would show, if you'd ask every owner to take one and submit it into like a huge archive, they'd show the percentage of getting bothersome glow.
Baddass does not seem to understand how you can take a properly(or extremely close to eye level) exposed photo even with a basic phone... video recording.
will vary by sample, Dell are probably as good as anyone in terms of support so you could try another one if you were happy with the screen/specs and at least you have good support etc to back it if needed
