- 29 Aug 2010
- Cornwall
You can look at it the other way. What if AMD marketed the Fury X with 800MHz core clock but they all operated at 1050MHz? Then AMD would be providing "buyers a product that exceeds the specifications to give the user the best out of the box experience." So you can look at it both ways, nVidia under-advertise the clocks to make the results look better while AMD advertise accurately - or look at it your way that nVidia are giving away free performance while AMD are locking performance down. Depends which spin you want to put on things.
As I understand it though it's not a case of Nvidia stating a lower speed it's the fact that cards will boost to different levels based on whatever it is (ASIC?) so not all MSI Gaming cards will boost to the same speed. They'll boost to what they can, giving the user the best experience out of the box.
If AMD just change the specs on the box it's still not doing that. They'd actually need the FuryX to boost 1076MHz on one card while stating 1050Mhz, but then on another card boosting to 1084MHz while still stating 1050MHz.
Unless I've misunderstood the whole Nvidia boost mechanics?
175w Nano.
AMD is leading already and are extending their lead next year.
Backed by Dx12/Mantle their own developed software used world wide.
cant say nvidia done much for us PC gamers the last 20 years.
GSync? Which led to Freesync...
ShadowPlay? I'd compare it to Raptr, but more in concept than execution.
HDMI 2.0 connectors...
Voltage control on their top tier cards.
Release day drivers.
Sponsoring games.
GameWorks.
