can you mix n match different 980ti cards of different brands in sli configuration?
coz i want to go sli but if i get a 2nd Zotac amp extreme then it will take up a much needed pcie slot, that is if i get a 2nd identical card, each card takes up 3 slots.
However if i get a different 980ti brand that is the thinner cards that takes 2 pcie slots, will that run ok? or will the drivers play up?
also 2 cards equals less power drawn from each card which means less heat? am I right?
people say sli gets hotter to which i dont get? wont it be cooler?
