Has anyone ever had a D5 pump die on them?
Got a D5 in a loop that's been running fine for a month now, started up the PC this evening and the fans are going wild and core temp shows the cpu at 70 degrees on idle!!!
I noticed that there isn't the normal turbulence in the reservoir when it started. Tested it on a separate psu and it's not working
Thought a pump would generally be reliable.....it's normally so silent and had no signs of going.
Anyone had this before? Draining the loop and swapping the pump will be such a pain
, don't want the thing bursting into flames if the pump dies. I might put a flow meter in next time I replace the fluid, that would be a better way as it will shut down as soon as the flow stops rather than on temperature.
