is the best windows phone the nokia 1520?
28 Aug 2013
ive currently got the nokia 930 windows phone, amazig phone, ive just spotted the 1520 which is basically the 930 but witrh a larger screen, is the is the best windos phone on the market? or is there a better one?
I know the 950 is out soon but will wait for that and get that one later
thank you
Might as well wait for the 950. As you say 1520 is virtually the same as 930 a few improvements like glance screen
950 is out ~12 December.
Also, I don't think the 1520 is on the list for an upgrade to Windows 10.
It is a nice phone though, miss mine.
I do plan maby on getting the 950 but I'm after a windows phone with big screen, don't doppose you know if you can copy the phone ie copy the entire 930m over to the 1520?
cheers
ok didn't think it was as big as that, will wait a bit til its cheaper I like the idea of the display dock amazing wondering if the phone will connect to any Bluetooth keyboartd and mouse?
thabk you
What do you mean by copy the phoneover?
If you go to settings > back up you can see what you can back up. And then when you get a new device it gives you the option of starting a fresh or using that back up. Even I its a different model.
950xl is a big screen 5.7"
Why would you say that.you can get w10 insider on it right now.
This list is a couple of months old. There was a leak from a Polish site last week where the 1520 was also missing, I'll see if I can find the article later.
It has the insider build but the official release won't be made available. Not sure on the details, just something I noticed in my RSS feed. Don't keep up to date with Windows Mobile.
Edit : Here's the leak from Orange Poland. Could be in the 2nd wave in Feb 2016 though.
99.9999999% chance of being utter rubbish.
Ms have already said they'll update all they physicaly can. Including devices with just 512mbs.
It might not even be a proper leak. Ontop of that did orange Poland even carry said phones. If not they wont be issuing an update anyway. As none will have orange specific rom. Instead will be coutry variant direct from ms.
