I would have thought you just use any mortgage calculator and keep moving the slider until it fits your budget.
The general rule is 1.5x your salary but you would rarely get a 100% mortgage
Most banks will lend you more than 1.5X your salary. When we were applying recently it ranged from 2X-4X my individual salary.
For the last 18 months (and longer for some) banks/morgtage providers haven't used salary multipliers, actually taking the affordability of repayments as the primary decider in whether to approve your loan. So what other outgoings you have will drastically affect the amount you can borrow.
The easiest way to get a ballpark figure is to run numbers on money supermarket or similar.
There are obviously implicit multipliers within that, but it is just down to whether given your normal expenditure you can afford it, it was a requirement that came in last year.Almost all do now go no higher than 4.5x, or at least this was the case from April to August.
Shop around as well as using a broker. We made the mistake of using a broker through a family recommendation, in the end we didn't get as good a deal as if we'd gone to First Direct or even Natwest.
Back in the 90's you would get a 100% mortgage(even if a student) plus another 10% on top for extras. The days!
I honestly thought they changed that after the last crash due to irresponsible borrowing (obviously not irresponsible lendingwe can't blame the banks)
The interest rates won't stay this low forever
Find a mortgage broker, not a bank. It's free to get quotes they will explain anything to you.
Also read up on money saving expert, they have a newbie guide![]()
