Apm is disable which i saw in the other thread, the temps have nothing to do with the vrm's.
The op just has a real hot chip or air flow is not right, is your cooler fan facing the the gpu.
What temp is it getting to with 1.3 volts.
Edit was thinking of HPC, look if your board has the latest bios.
No the board is hitting ocp the rev 3 had serious issues,
Apm is not disabled as he doesn't have it in the bios.
There's no cure for the classic throttling to 3.5ghz on his board when tmp1 hits 60c.
Tmp1 has never hit 60c as thats the motherboard, do you mean tmp2 if thats the case, he has to put a fan over the vrm's.
I did tell the op to get the ud3p as i know its a better board.
