- 11 Sep 2014
- Suffolk, England
Welcome, to my second project build log! My first being project Molten Gold, in which I built my first ever custom loop with a black & gold colour scheme. With this new project, I plan to take things one step further & not only custom build the pc, but the case too!
I plan on using wood, glass & aluminium as my core materials for the case and I will make my own custom length sleeved cables for all possible components too. I'm yet to decide on a colour scheme for this build, but I'm thinking of a two tone theme. The wood I'll be using will be reclaimed from wooden pallets, just like I've done with my desk.
Below is the original design/layout I had in mind, before I got my hands on a pallet & spare parts for testing. After getting the pallet & cutting the wood to size etc, that layout wasn't possible & didn't look right, so it's been changed. Progress images & posts will be further into this log.
The components I plan to use for this build are listed below (this may change as the log progresses):
Mobo: Asus Z170-A Intel Z170 (Socket 1151) DDR4
CPU: Intel Core i7-6700K 4.0GHz (Skylake)
GPU: OcUK GeForce GTX 980Ti "Reference Design" OR OcUK GeForce GTX 980 "Reference Design" Depending on my budget
RAM: Kingston Fury Black 32GB (4x8GB) DDR4
Storage: Kingston HyperX 3K SSD 480GB
PSU: Corsair RM Series RM 850 '80+ Gold'
Fans: Corsair SP120's (possibly also AF120's/AF140's)
Radiator: XSPC EX240 Crossflow
CPU Block: Aqua Computer Cuplex Kryos XT .925 Silver Edition
GPU Block: EK-FC980 GTX - Acetal+Nickel
Tubing: Hardline (brand undecided)
Fittings: Monsoon Free Center Hardline 1/2 X 5/8 (16mm) 6 Pack - Green
Reservoir: RAI-R10 or RAI-R20 (Black)
Pump: XSPC D5 PWM + Bitspower D5 Mod Kit
This build is planned as a high end gaming machine in a small package, allowing me to travel with it with ease. This build was inspired by a game called Ark: Survival Evolved which is in Early Access on Steam right now. It's pretty demanding in terms of hardware, and my poor little system isn't up to the task of running the game at max settings. If I have chosen any parts which aren't suitable for the intended use, feel free to suggest replacements and explain why
This log will be a long & steady one, so sit back & enjoy!
But for Christmas, I should hopefully be getting the Monsoon hardline tube bending kit, some hardline & fittings
