They were really good, they now sell them at a higher price due to that! Went in to buy 2 more and they were 4 quid each.![]()
eh? Surely the point of pound land is that everything is £1?
At work I get HDMI cables for 85p each. Consumers get fleeced in pound shops I tell you!![]()
Thing is a bad quality HDMI cable WILL cause erroneous data transmission. It's not as simple as "it will either work or not". There's a million+ pixels to be fed continuously with data. Transmission errors in a continuous digital data stream can and do occur, and will manifest in the form of small and barely visible artefacts.
I've had a couple cheap cables and they cause very small errors/spots at the sub-pixel level, you have to put your face a couple inches from the screen to actually see it but bad cables do cause problems.
Before anyone says, no I'm not saying it's worth spending more than £15 on an HDMI cable, I'm just saying some really cheap ones do cause data loss.
I would reccommend OcUK though, the cable I purchased years ago is still going strong.
I know that.
But if a potential customer says 'No' to a ridiculous cable, 'No' to accidental damage cover, 'No' to a TV stand... surely having to say it once is enough?
Why should I have to repeat myself about twenty times "I just want to buy the telly!" over the course of about 10 minutes of actually just trying to buy it!
Don't they want the sale? They very nearly lost it!
Haribo !
TBH first hand I did buy ultra cheap HDMI cables for my screen/ and PC.
Both of them resulted in having some kind of weird interference and snowy static over the images. I'm not saying you have to pay for expensive ones, just one up for the ultra super cheap ones you see about.
You shouldn't ever get static on any display using HDMI cables (or if you do it's not the cable at fault).
HDMI is digital with a fair amount of error correction, if you get a problem it will either be blocking (like a scratched DVD or poor digital TV signal), or a blank screen/no audio.
