** XSPC RAYSTORM PRO - THE ULTIMATE BLOCK FROM XSPC **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
I totally forgot to launch this product, it has been on order and on our backend for a while now.
Here it is, the fantastic new XSPC Raystorm Pro
A block made with a new mounting system designed to produce even pressure across the CPU as well as giving a precise mount each time.
The Raystorm Pro will be a huge contender in the market this year.
XSPC RayStorm Pro WaterBlock (Intel) Black @ £64.99 inc VAT
The RayStorm Pro is the highest performance and best quality waterblock XSPC have ever made. The waterblock top and new high performance base are CNC machined from pure copper, while the bracket is made from cnc'd aluminium with an acrylic insert for LED lighting. This give the block a solid and premium quality, appearance and feel.
As well as the performance and quality advances, we have introduced a new mounting system that’s easier to use and applies the correct pressure, every time.
Solid aluminium bracket with acrylic inserts
New, high performance copper base
CNC cut, pure copper top
2 x 3mm LED holes
G1/4? threads
Compatible with most compression fittings
Supports Intel sockets 1150, 1151, 1155, 1156, 1366, 2011 and 2011-3
Supplied with mounting hardware, 1150/1151/1155/1156, and 1366 backplates, twin blue LED, allen key, and K3 thermal paste.
White, red, green, yellow, orange and white LEDs sold seperately.
Only £64.99 inc VAT.
ORDER NOW
That "in" looks awful.
Looks great apart from that.
