Titan X SLI stack with one Hybrid cooler
30 Mar 2015
Hi guys ive got a TiTAN x sli i have one hybrid cooler on the top card temps have been low 55oc top card 70oc bottom in Shadow of mordor 4K Maxed AA on playing for well over a hour.
i am thinking of buying one more hybrid cooler for my bottom card or i could buy a small loop to water cool my GPUs only
as i have a H100i FOR MY cpu i'm just undecided on what to do guys i've not done a water loop before
any help welcome
If you are putting the GPU's in a custom loop it would be rude not to put the CPU in too.
It looks like you like aios so go for another?
Might wanna put the pic into spoilers or resize :)
A Hybrid cooler would be the easiest option. Going full custom water would be the most expensive and time consuming, but done right a watercooled rig can be cool quiet and look awesome. For simplicity I would go hybrid cooler. Great temps, less hassle.
2 Titan X's in SLi in a mATX case with a mATX board :eek:
Get a bigger case and a board with better spacing then you won't have to worry about high temps as much! ;):p
Yeah when i got the case in April 2014 i had one 780ti classy seemed like a good idea until i got the Titan Xs and 4K :( i was a total noob then got advised on what to get i had 1440p then
Thanks guys think i will go with one more my next build will be a bigger case and a waterloop learnt my lesson with this small case lol
Thinking of putting my H100 at the front bay and my hybrid coolers at the top as they are bigger and don't think it will fit at the front.
also would you guys change the fan on the hybrid cooler? i have noctua 2000 rpms on the h100 and back exhaust, with 140mm NF-A14's in the front bay
my top card is EVGA and bottom is ASUS i hear Asus dose RTM cards if they have been opened? what the case with them
Cheers guys you have been helpful
Temps seem pretty good as is. As it stands 70 degrees under load is fine, I'd be very happy if I was you.
I find Dying Light to be a good game for testing temps try a couple of hours of that if you have it and see how hot they get.
I have my 980s both on Hybrids, they work really well, are quiet, give me a good overclock (both cards hit 1530mhz boost) and they never go over 60 degrees.
That would seem hot for a CPU but for a GPU I'm happy with that temp.
Yeah ive been useing Shadow of Mordor for testing as in 4K it seems to push the cards a lot, if using one card in Fallout for only get temps upto 45oc
2 AIO's works great
do you have the corsair SP on your hybrids rads?
did you get better cooler by replacing them?
Yeah that sounds like a good overclock and with my bottom card getting quite hot it can get loud is quite annoying
when i get one more it should keep them in the 40s i think as the top dose not go over 50oc at the moment
