I'm not sure if the Zotac has the zero-fan option but I'd set a 1:1 profile in MSI Afterburner. That'll ramp up the fans when it gets a hot.
That 100% sounds like something is up. I have a friend who barely hits 68 on full load on stock.
So is there something wrong with my card.
Everything stock, card on full load, fans on 100%. case open.
Temp at 81c with the card clocking its self between 950-1025mhz.
I made a thread ages ago about the temp, so i got a new case but its still happening...
Thoughts on a bad card?
Could be rubbish thermal paste. Have you tried replacing it?
yep, got furmark on gpu stress testing.
currently at
100% load
83c
911mhz clock
3505mhz memory
no overclock at all. Help guys?
Uninstall the card physically, reseat it in another slot reset to default all overclocking software, ddu driver uninstall and reinstall latest.
Try that first
The card was doing it on my old system, an i7-2600k in a bad case which convinced me to upgrade the case while doing the cpu for better airflow
So its had a fresh install and is continuing![]()
