My sons BMX has one rear brake only. It's a U brake set up. The pads engage the rim with very little force to the lever on the handle bars so I don't think it's a cable issue(?) The problem is that once he sits on the bike and brakes even though the pads make full contact the rim it is still able to move quite easily. If he gets off it and puts the brake on and pushes then it holds the wheel in place so it's failing once there is weight on the bike.
Will new pads fix this? If so is there a particular type? He only rides it to school and back.
