no problems with 100hz on the gsync version!
Whats it like compared to the 144hz on the swift? Can you tell much difference?
really looking forward to buying one now.
i didnt have a swift before i came from a 27" 1080p samsung 950D 120hz..
this at 100hz and my 120hz samsung is exactly the same cant tell any difference..
gsync is amazing tho as is with IPS + the curve is just right imo... games are so immersive!
Does anyone know if the curve on the Predator is less than the Sammy 34" ultra wide?
I had a Sammy for a bit but did not like the VA colour shift or the curve (curve was too much for me distorting images)
If the curve is less than the sammy I'm tempted to try this panel out if so!?
Got a screen that couldnt do 100hz, get some wicked flickering on the X34. Got it to 95HZ and everything is smooth. bit gutted but dont even know if its returnable and if i can be even bothered.
***EDIT*** When i overclock the monitor to 100hz its fine as soon as i put 100hz in the nvidida control panel it goes crazy. If i creat a custom resolution and set it to 99hz its fine, im confused? :s
***EDIT EDIT*** Flickers even at 99, 95 seems stable. Could this be a DP cable issue?
Could be, id be tempted to try the best quality/shortest reach dp cable you can get.
I will try the short ass one they supplied and see what happens![]()
Now that's a thing of beauty Westie![]()
