- 22 Jul 2015
- Aberdeen
my biggest disappointment is that nobody is willing to do a good deal on 5960x. I atleast hoped that OcUK will take lead on this
My mistake - I got four bags of haribosI got three - thanks for reminding me, I'll have one with my coffee in a sec
Would you buy if I looked into a MATX option first thing Monday then???
hi
case arrived today which was an unexpected relied a bitfenix ronin. very nice piece of kit considering the price.
it is all set up now and installing win 10. but 1 possible problem if you could adviseplease.
my corsair gold 650m psu is semi modular and i cant believe it but i seem to have lost the extra cpu power module (my old pc did not need it and i removed unneeded wires).
this board suggests it is needed if you plan to overclock so i am stuck at stock.
has anyone tried overclocking without them. i have never every heard of a motherboard needing 4 differed psu connections for power.
thanks
Will there be an matx option coming up?
my biggest disappointment is that nobody is willing to do a good deal on 5960x. I atleast hoped that OcUK will take lead on this![]()
Realistically you dont need all the screws just a couple of corners through each fan and rad.I can't seam to fit the rad on the Enthoo Luxe. Anybody having the same issue? The gap between the two centre screws is too long. It means I can only fit it with one screw?
Any suggestions please?
Thanks.
Realistically you dontyneed all the screws just a couple of corners through each fan and rad.
Does the Luxe case not use elongated grooves instead of standard fan screw holes for top mounted rads/fans? I've got the primo here which uses this style of mounting.
1 8pin connection is fine.
How have you guys with the Enthoo Luxe connected the radiator fans? The cables aren't long enough to go to the PWM controller. There was a reference to a fan Y cable in the case's manual but I didn't have one in the box of bits.
I hace suggested this yes. Will work on Monday with Gibbo but donty expect it on teh website then it will depend on several factors.
ThanksFans under rad. Rad screwed in at the top. One fan could reach the PWM other is on the motherboard.
Not got this far yet, ended up going out for 5 mins to sort out a friend and his tablet and it turned in to 5 hours. This evening I hope, although I'm going to plug my M.2 drive in to the ASUS carrier I bought at the same time.I'm having a few issues..
Not picking up all my ssds, not detecting the M.2 mouse and keyboard only work in safe mode.
