Yes - my aim was getting big block to avoid noisy work any time - no matter what I am doing on PC. I am not being funny but if the fans suddenly stops I probably wouldn't notice thattomekkk1 said:Now i7 4770T, together with mx-4 and Be Quiet Dark Rock Pro 3 presenting 27°C idle and 56°C max stressed with OCCT (small data set).
It can handle up to 250W TDP, so with just as little 45W it got really easy life
Yes it's about 115x sockets - glad you notice that. CheersGood explanation of be quiet! mounting on 115x mobos, tomekkk1.
But 2011 mobos have backing plate built in with threaded holes to the front. I don't think mounting from the back is possible.
I've got a dark rock pro 3 sat here for a few weeks now waiting to fit, my main concern is whether it will interfere with the first PCIE socket/GPU.
Which Z97 board?I'm on Z97
looking at the pictures I can find online with it fitted to a motherboard I dont think it will interfere with the first socket
be quiet! dark rock 3 Installed. This cooler looks awesome. Temps under full load are 68c. Glad I went air cooling
Nice one, bro! Looks stunning there
If that 68°C you've made using RealBench or OCCT bear in mind you'll never reach it in your games & programs![]()
This cooler is a looker.
Yes I used prime95. Gaming should be a lot lower. So far extremely happy with air cooling. Temps are much better then the corsair H105 I was using. Think I'll stay air for the near future. Can't trust AIO any more.
Probably you've fit it wrong - I have be quiet! Dark Rock Pro 3 and retention plate is on the place. Really no idea how the cooler is distracting in yours...
I'm on Z97
Which Z97 board?
be quiet! dark rock 3 Installed. This cooler looks awesome. Temps under full load are 68c. Glad I went air cooling![]()
