Caporegime
- 9 Nov 2009
- Planet Earth
Would you recommend the kfa? I've not heard too much about them in general, mostly I've been recommended the Asus strix, but haven't seen/heard great things online about it.
For around £400 you can get a Fury which is generally a better card at higher resolution too. At under £300 you can get an R9 390X or one of the better R9 390 cards like the R9 390 Nitro.
Plus,with the next generation GPUs out next,I probably would try to spend less if possible - the extra money saved now will be better used towards an upgrade in 2017 IMHO.
