Safe to use?
Yes some can damage charging equipment, including the official OnePlus cable.
Safe to use?
What phone are you using it with? N6P or OP2
Well it's the 6P thread, so...![]()
Well were talking about a OP cable so it could be either.
It still depends on what you have it plugged into, if its capable of 3A its fine.
Does anyone else use lightflow? Just got my 6P today and if I have ambient display on and use lightflow to customise my LED notifications, the screen keeps "ambient displaying" even when I have no notifications.
It''s not the end of the world as the LED shows I have a text or whatever, just wondered if anyone else had come across it.
Its a known bug IIRC, there was a thread on Reddit.
Edit:
https://www.reddit.com/r/Nexus6P/comments/3spvxf/lightflow_filed_a_bugfeature_request_with_android/
Air vent holder of choice is the Kenu Airframe+
how well do they hold? i just feel with the vibrations of the road something this big will easily slip right out, esp without having anything at the bottom side to keep it in place.
It doesnt work on my connection.
If you can't provide a better link or short explanation then don't reply.
