New power supply for 290x?
16 Aug 2011
I want to buy a sapphire r9 290x tri x 4gb but not sure if i need a new power supply , i have a 750W power supply with these cables attached:
Im not sure if this card is 8pin ? can someone help me.
Thanks
That card requires 1x 8 pin and 1x 6 pin pcie connections. Which you appear to have going by the image. As long as it's a reputable brand psu your good to go.
Removed
product description
Product Descriptions
Peripheral / Interface Devices CD-ROM, PCI Express 6-pin power connector, power connector PCI Express 8-pin Minimum RAM: 4 GB Power requirements: 750 W, Package Type: For sale retail Compliant Standards: WHQL, Software Included: Drivers & Utilities, AMD Catalyst Control Center, Height: 11.3 cm Cables Included 1 x HDMI cable - 1.8 m, depth: 30.5 cm Included Accessories: Power cable 8 to 4 pin power cable 6 4-pin, Width: 3.8 cm, Technology: GDDR5 SDRAM Effective Clock Speed ​​5 GHz Bus Width: 512-bit size: 4GB
Just google my power supply and here are the connectors
1 x 4+4pin CPU +12V 4 x 4pin Molex 1 x 6+2pin PCI-E Power 1 x 6pin PCI-E Power 8 x SATA Power
Hi its this card
product description
Could you please remove the competitor link.
As i have stated in my earlier post, your psu appears to have the correct connections. On one of your six pin plugs, there are two extra pins that slot on to form a block of eight pins.
Yup psu will be fine.
If your set in a 290x buy one off eBay used as they sell for a lot less than that one you linked too
