- 2 Dec 2015
Hi Guys
Hi there, I have following:
Old Setup:
BG 330+ (Glow worm re-badged)
RC Plus wireless thermostat in hall
Timer/control Model UT2 in cupboard upstairs with hot water tank. Boiler downstairs in Kitchen
New setup/addition: BG Hive thermostat - dual channel heating and hot water
I bought the new Hive 2 kit for 'heating and hot water'. I unclipped the timer/control UT2 and clipped the new dual channel receiver onto the back plate.
I setup rest of the Hive gear and its all up and running, except that the it doesn't start and run heating. Hot water works ok. I can access the thermostat from my phone and the internet and despite it saying heating is on (even if I set the temp to maximum) the boiler doesn't fire up.
The central heating light on the receiver lights up when expected but boiler not turning on.
Any ideas? I believe there isn't enough cores in the wires on the back plate as the UT2 is a single channel and doesn't control the heating but only hot water.
What I have noticed is that marked as number 4 on the new backplate for the receiver doesn't exist on the back of the UT2? I haven't changed the back plate to new one, old backplate has just been left and new receiver connected over onto it.
I've put batteries back in to the RC Plus, leaving all the new setup in situ, and when I turn temp up on RC Plus the boiler fires up and central heating kicks in! must be wiring needs re-configuring and I need to work out the missing cores at the old back panel of the UT2, any help appreciated please.
Is it possible to connect the new Dual channel receiver to the back panel of the Wr1? will this work?
Pictures here as I can't see a way to attach them to post HERE
Many Thanks in advance
Old Setup:
