Here's the innards of my PC
It's a little dark. I'd like to show off a little, and I thought I might do so with some LED strips, of which OCUK has a plentiful supply. My initial thought was a long green strip facing inwards
to go with the green GPUs, and to fit the strip on the inner upper lip, but the FT05 is so bad for cabling - neat cabling anyway - and the panels are padded for noise control (as you can see on the right) that I'm concerned about a good fit.
Or I could go purple to match my Ducky Shine keyboard.
The other thing is that my EVGA SLI bridge glows white. Can I change that?
Any thoughts?
Any thoughts?
