- 10 Apr 2014
- Hampshire
Got a bit bored so I thought I would upload pics of my ps4.1 and show the cooling "mods". the way it looks is just a sticker I bought off ebay, it isn't one full sticker but different parts that stick to the top/tides.
yes , I know the warranty is void and I couldn't be bothered to wait for it to die on me with a valid warrant. saves me flying about sending it off to sony to get another.
I started to do this because when I got my ps4 it was getting ridiculously hot and I didn't want it to die on me. first I looked on youtube to see if anyone else had come up with a cooling mod for their ps4.
1 guy that I came across had done the same thing as what I did, which is where I got the idea. cut out a hole directly where the fan intakes air on the inside.
then I used a fan filter/case to stop the actual filter getting fluff on the inside , although the dust Is still a problem. the black frame holding the filter in place used to be an 80mm fan that I bought from china or hong kong for £3. I ended up just tearing the actual fan out because it was causing more heat than helping keep the temp down.
I also bought a device from ebay that plugs into the fan and then into the fans power source that boosts the fans speed while the ps4 still "thinks" its only moving normaly. couldn't get the top case off though to show the device.
had to set it on blocks so the filter/frame has clearance.
anyone else made mods to help cooling? I have seen water cooling mods on youtube but don't think i'll try those.
also thinking of buying the new model which is more efficient.
all views welcome (Y)
