As a complete SweetFX n00b, what do I need to do to get that installed and running on my system?
Outlined in the guide but I will reaffirm as someone who has done it, for peace of mind more than anything I assume:
How to install:
1. Download, extract and launch ReShade Setup @
http://reshade.me/#download (safe link, checked it for you)
2. Select game /Grand Theft Auto V/PlayGTAV.exe
(there is only button on this program from what I can remember)
3. Autodetect should fail, so select Direct3D 10/11
(chose 11 unless you hav set GTA to run at dx10)
4. Close all windows
5 Download preset and rename to "SweetFX_settings.txt"
6. Copy SweetFX_settings.txt to \Grand Theft Auto V\SweetFX, overwriting the existing file
7. Launch game
8. Adjust In-game brightness to your taste
9. Toggle mod using Scroll-Lock
If it doesn't work for whatever reason, you can delete everything it adds in so take a screenshot of the default GTA folder before starting.
In addition, if it also fails, I will zip my settings and upload them for you so you can just extract to the game directory.
No pain process
EDIT: I might actually change my sweetfx setting at some point for a change. I think the only reason I have kept mine for so long is because it looks epic, and also doesn't glitch menus.
