- 19 Feb 2007
- Northampton
Just wondering if anyone's heard if Nvidia will put something like AMD's LFC into motion or is something like it already here ?
I think Gsync has been doing this from day one.
Well I was just watching an AMD video and they were talking about when the games FPS goes below the Freesync threshold which on some monitors is 35Hz, LFC kicks in and considering G-Sync is limited by 30-165Hz currently I was curious.
G-Sync works all the way down to 1 fps Dice.
Not in display though.. On paper it does.. It's limited atm by the monitor and that is 30hz.
I might be wrong but I think G-SYNC starts duplicating frames in low framerate situations and starts rendering at higher multiples of the refresh rate instead of dropping down or capping at a lower refresh rate - which it can do thanks to the FPGA and freesync can't apparently. Which means that when new frames are available at a higher rate than the current one it can display them more quickly on the screen while with freesync you have to wait for the next update at the current rate before it starts increasing?
Like above I sure Gsync has had this from start it's one thing pcper tested that time with fancy tech they was using..
Yup that's where I remember seeing it, they had it still smooth at 9fps....as if we would want to play anything at 9fps.
To be clear this is not the first time this type of technology has been released as NVIDIA’s G-Sync has already had the feature present since its launch. This was possible because of the embedded hardware module that comes with every G-Sync monitor. Since AMD’s FreeSync does not have its own module the company has resorted to using software to implement this function.
Anyways anything 30fps just isn't enjoyable no matter what tech we using..
