Hi all,
I'm speccing out a new rig and want to try my first WC build - equally for the noise reduction, extra cooling and aesthetics. I'm looking at an X99 rig with CPU watercooling and an Asus Poseidon 980ti, in the same loop. I've been looking to try and find some way of (relatively straightforwardly) hook a decent amount of radiator to the area currently occupied by the 200mm top fan. I've had a google but I can't see too many examples of this being done before?
My second question is around how much radiator space I'm likely to need for that set up. I'm thinking if I can get something in the region of 200x200 in the top and then likely a standard 120 on the back in series. Would that be enough cooling for the CPU and 980ti?
Whilst I'd much rather keep the case I have, I'm open to the fact that I may have to get a new one - so I'm equally keen to hear from people if you think its just not going to be possible. As the case is beastly enough I'm steering clear of an external rad.
Thanks in advance for any help you can offer!
