- 18 Mar 2012
- Eastbourne
Ah okay, you could also change the fittings, they can bring down the cost.
You could swap for the OcUK fans, that would save you £20.
I don't know what block you need for your card, you could go for a thermosphere type cooler with vram heat sinks to keep them cool.
You don't need the hose cutter, you can use scissors but it doesn't make a very clean cut.
You won't need 5 litres of coolant
Yeah 8 would work but you may need things like 90 degree bends etc.
That res thing looks horrid in my opinion!
