Can you take a screenshot of the GTA folder?
Also if you run the game, what happens?
Finally - which exe did you select? PlayGTAV.exe?
There are 2 GTA V .exe's in the folder, 'GTAV.exe' and 'GTAVLauncher.exe'. I chose the 'GTAV.exe' one.
Not sure what happens if I run the game, will do so now and post back. Here's a screenie of the entire folder:-
**EDIT** I get this if I try and play the game from the button in ReShade:-
The reshade must assume the non steam version for the exe so don't worry about it at all, just use the normal gta exe.
