- 1 Jun 2014
Hello OcUKers!
I'm not looking for an actual spec right now (next month maybe), because final budget has yet to be decided. But I'd like to know the general consensus on which platform you think would suit this build best, given that;
My main thoughts so far are that the extra cores on the 5820K might give it a bit more longevity over say a 6700K, but would obviously give me no choice as regards which motherboard to use. I think it also slightly limits cooling options??
What other factors should I be looking at? Is there a big difference between the available features of both chipsets, for instance? How about thermals? I'll be in university for the next few years, so it's unlikely I'll be upgrading during that time, but if this was your build, would upgrade path come into your thinking?
Hell, is Devil's Canyon still an option?
That's all I can think of for the moment. Just looking to start a discussion really, and get a few ideas. Thanks in advance.
- the computer will be used primarily for gaming (with the usual browsing and Netflixing thrown in too), 1440P now, maybe 4K later
- the CPU will have to last ~4 years (pretty much right through university)
- it will be an ITX build in as small a case as I can get away with, but I'd like to use an AIO cooler
- I'll be overclocking
