OcUK Staff
- 26 Nov 2014
- Stoke
We're happy to introduce the new SL-2000 & SL-4000 series in white variants. The SL series has proven extremely popular since it's introduction and these new models add something different to whats available in the market. As the units are made with PVC leather rather than PU, there should be no discolouration over long term use. The chairs themselves look absolutely stunning and are fairly unique in the gaming chair market. Stock is due next Tuesday so grab yourself an early Xmas present!
Vertagear Racing Series S-Line SL2000 Gaming Chair - White/Black Edition @ £189.95 inc VAT
A combination of form and function, Vertagear’s SL-2000 series focus on ergonomics, design, and functionality. Designed to give wide range of adjustability that gives gamers the best comfort and support in every gaming position for extended period of time. High backrest is designed to provide neck, shoulder and lumbar support.
Adjustable seat height
To prevent repetitive stress, having the correct ergonomic posture is important when seated for a longer time. Seat adjustability makes sure every type of user from different heights can adjust the chair to their unstressed posture. Good range of height adjustability to ensure you are at the optimum angle in relation to your desk.
Adjustable armrest
Cushioned and contoured to the shape of the arm with adjustability in height gives support to the gaming arm and prevents repetitive stress.
Adjustable back
Features independent back angle option. An angle-adjustable backrest to help you adjust your sitting position throughout the course of your gaming experience (up to 170 degrees).
Elegant Exterior
The SL2000 is made of high quality PVC leather, which makes it extremely durable and gives the chair a luxurious look. This material is easy to clean and maintain due to it’s stain- and water-resistant characteristics.
Comfort Padding
The SL2000 padding is made of high densed foam, which adds great support and seat comfort to the chair. The open-cell breathing structure, makes sure that heat arised from the human body temperature won’t get trapped inside. This gives great comfort to the user even when seated for extended period of time.
Solid Structure
The SL2000 is constructed from a steel frame that assures a solid structure. The aluminum alloy 5-star base keeps the chair solid, stable and lightweight. Assembled with a Class 4 gaslift, iindicates for better durability and ease of use. Our Class 4 Gas Lift has thicker walls to accommodate the higher pressure and stability.
Tilting feature with adjustable resistance and locking system
Our adjustable tilt tension mechanism allows you to increase or decrease the tension by easily turn the knob to match your body weight. This allows you to rock comfortably, without heavy pushing, reducing muscle fatigue.
Extra accessories
Additional neck support cushion and lumbar support cushion is included.
Soft-glide Wheels
Wheel is formulated for a quieter operation and greater resistance to foreign objects and debris.
Specifications
- Overall height (incl. base): 1280 - 1360 mm
- Width backrest (shoulder): 555 mm
- Width backrest (lumbar): 290 mm
- Width seat: 370 mm
- Depth seat: 540 mm
- Material(s): Steel (frame), High density resilient foam, PVC leather, Aluminum alloy(feet)
- Max. Load: 150 kg
- Colour: White/Black
- Model: VG-SL2000
- Net Weight: 20 kg
- Gross Weight: 24 kg
- Package dimension: 880 x 400 x 680 mm
- Warranty: 2 years
Only £189.95 inc VAT.
ORDER NOW
Vertagear Racing Series S-Line SL2000 Gaming Chair - White/Green Edition @ £189.95 inc VAT
ORDER NOW
Vertagear Racing Series S-Line SL2000 Gaming Chair - White/Red Edition @ £189.95 inc VAT
ORDER NOW
Vertagear Racing Series S-Line SL2000 Gaming Chair - White/Blue Edition @ £189.95 inc VAT
ORDER NOW
Vertagear Racing Series S-Line SL4000 Gaming Chair - White/Black Edition @ £219.95 inc VAT
Redefining gaming chairs, the SL-4000 brings unparalleled level of comfort and adjustability. Gamers spend hours each day in front of a computer, the new SL-4000’s high density padding and contoured backrest allows for an extremely comfortable gaming experience. Designed to give wide range of adjustability that gives gamers the best comfort and support in every gaming position for extended period of time. High backrest is designed to provide neck, shoulder and lumbar support.
Adjustable 4 point armrest
Cushioned and contoured to the shape of the arm with adjustability in 4 directions gives support to the gaming arm in every position and prevents repetitive stress.Ergonomically designed to provide support to the forearm, relieving muscle strain and fatigue from the shoulders and taking pressure of sensitive areas of the wrist.
Adjustable back
Elegant Exterior
The SL4000 is made of high quality PVC leather, which makes it extremely durable and gives the chair a luxurious look. This material is easy to clean and maintain due to it’s stain and water-resistant characteristics.
Premium Padding
The SL4000 padding is made of high densed resilient foam, which adds great support and seat comfort to the chair. The open-cell breathing structure, makes sure that heat arised from the human body temperature won’t get trapped inside. This gives great comfort to the user even when seated for extended period of time.
Solid Structure
The SL4000 is constructed from a steel frame that assures a solid structure. The aluminum alloy 5-star base keeps the chair solid, stable and lightweight. Assembled with a Class 4 gaslift, for better durability and ease of use. Our Class 4 Gas Lift has thicker walls to accommodate the higher pressure and stability.
Extra accessories
Soft-glide Wheels
Specifications
- Overall height (incl. base): 1280 - 1400 mm
- Width backrest (shoulder): 520 mm
- Width backrest (lumbar): 300 mm
- Depth seat: 530 mm
- Material(s): Steel (frame), High density resilient foam, PVC leather, Aluminum alloy (feet)
- Max. Load: 150 kg
- Model: VG-SL4000
- Net Weight: 20 kg
- Warranty: 2 years
Only £219.95 inc VAT.
ORDER NOW
Vertagear Racing Series S-Line SL4000 Gaming Chair - White/Green Edition @ £219.95 inc VAT
ORDER NOW
Vertagear Racing Series S-Line SL4000 Gaming Chair - White/Red Edition @ £219.95 inc VAT
ORDER NOW
Vertagear Racing Series S-Line SL4000 Gaming Chair - White/Blue Edition @ £219.95 inc VAT
ORDER NOW
Adjustable armrest
Adjustable back
Elegant Exterior
Comfort Padding
Solid Structure
Extra accessories
Soft-glide Wheels
Specifications
- Max. Load: 150 kg
- Model: VG-SL2000
- Net Weight: 20 kg
- Warranty: 2 years
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
Adjustable back
Elegant Exterior
Premium Padding
Solid Structure
Extra accessories
Soft-glide Wheels
Specifications
- Max. Load: 150 kg
- Model: VG-SL4000
- Net Weight: 20 kg
- Warranty: 2 years
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
