- 4 Nov 2002
- England - Leeds
Hi there, please can you help, I'm trying to play my games from my PC to my TV and for some reason it outputs at 24hz which means FRAPS shows 24fps and normally all my games run at 60fps so as you guys know, this means my games are unplayable on the TV.
The strange thing is when I launch hitman it brings up options panel before you go into the game on your desktop, I go in the options and it shows 24hz so then I change it to 60hz and launch the game and then it works flawlessly. It shows 60fps both on my PC monitor and the TV at the same time. So that shows that it does work with my setup and my hardware but I dont know what to do about all the rest of my games as they all output at 24fps.
Some of the games I've tried are GTA5, MGS, Wulfenstein, Battlefield 4, Assassins Creed Unity, these are all on different platforms such as steam, origin and uplay.
Also it might be worth me mentioning that my setup goes PC > AV Receiver > TV if that helps, my graphics card is ATI and I'm on windows 10, everything is connected using HDMI cables from graphics card to AV and then AV to TV. And I've only had this TV a few weeks so thats why I'm confused about this. In the past using my same setup I outputted games from PC to projector and never had an issue so just need to work out the best method for the TV.
EDIT: When I get home from work tonight I'm planning on trying a new method of output, I'm going to try output from graphics card to TV and miss out the AV and see if that makes a difference. If it doesnt make a difference though I'll still be confused! lol
Thanks in advance.
Thanks in advance.
