- 25 Aug 2013
My question is what is the benefit of putting fans with different characteristics (i.e. air flow and static pressure) on either the push or the pull side of the rad?
As I understand it, static pressure helps most when there is an obstruction on the side the fan is pulling air from, so static pressure optimised fans would surely be best at pulling through the rad, right?
If I put fans that have high air flow as push fans, would this be beneficial or not or just negligible compared to static pressure fans?
I also heard people saying that having fans that don't move enough air on the push side of the rad could choke the pull fans, but I would have thought that if the air is being pulled through a rad that a fan on the other side wouldn't really increase resistance much even if it is off, let alone if it is spinning and pushing air...
Thought this debate might be somewhat interesting
