Permabanned
- 12 Sep 2013
- Knowhere
You need to consider that AMD are slower in the driver department and they tend to increase a cards performance through drivers gradually. We are now at a point where from the benches I've seen on newer drivers the 390 tends to outperform the 970.
The majority are silent (zero spin) until load and then if you go with a good model like the Sapphire Nitro it stays quiet and temps are fine as long as you have adequate airflow.
Another negative for the 970 is the amount of complaints regarding coil whine.
This is on old 15.5 drivers, I suppose it's not included in the newer tests because the performance here is not as good as it is now, you can surmise from how neck and neck the 390 and 970 are in this older review and how the 980 and 390x compare in the older review compared to how they are in the newer driver review that if they had a 390 available for newer testing it would have pulled further ahead from the 970 at 1440 and matched/passed it at 1080. https://www.techpowerup.com/reviews/Powercolor/R9_390_PCS_Plus/30.html
