- 18 Mar 2010
You used the possessive noun when you meant to use a plural. The can does not belong to the worms, it contains them.
apologies it was an auto correct.
erm, no they don't... I have a wattmeter on mine and if I'm running a single 980ti at 144hz it uses about the same as reviews even with quite a hefty OC
reviewers do their tests with Vsync off, so what monitor they use for testing is irrelevant
Try on the desktop - 144Hz power consumption vs 60hz power consumption.
Maxwell needs to run full 3d clocks to power 144Hz on the desktop/videos etc.
The 390 has almost double the power consumption of the 970. Does anyone have a a handle on what that means in electricity bills. e.g if you were gaming for 2hrs how much would a 390 cost vs 970?
The 390 certainly uses more power but almost double is somewhat of an exaggeration.
GTX 970 about 160 to 190
390 about 220 to 250 < some of that is down to the 970 having 8 Memory IC's compared with 16 on the 390.
@ 50 Watts more and £0.15 per KWh its 20 hours of gaming per £0.15
Or 10 days at 2 hours a day, or £9.75 per year at 2 hours a day.
I am attracted by the fact that some of the 970 won't even activate their fans until the get past a heat threshold, conversely I am concerned about the hear/ noise of the 390.
From what i read there are a few nasty implementations of Freesync but not any G-sync
This is just so wrong lol.
Why? Do people believe every single rumour they hear?
The MSI 390 does exactly the same the fans don't start spinning until the temps hit 60c and that means gaming the fans aren't any noisier than any other card I've owned. Otherwise its silent.
I know lol, he even forgot to mention two situations with Amd lol.
Firstly that the Amd 390 has a 618% increase in power consumption compared to a gm204 970/980 during video playback.
11w to 79w
Secondly the Amd 390 has a 640% increase in power consumption compared to a gm204 970/980 during multi monitor usage.
10w to 74w
