This has PWM so how would I get full power to the pump when filling/bleeding system ?
If you dont connect the pwm signal, it runs at full speed
It might run at full speed if you don't connect the PWM, although there are multiple threads with people with issues running these @ full speed to fill them without PWM.
Best suggestion is to get a constant 5v feed and apply it to the PWM pin for the pump, this will force it to run at full speed.
There should be some threads on here which explain how to do that.
Does it take like 30mins for the liquid to get around to the end of the loop if it's on the Lowest pwm setting?
I'm about to do mine and have a pwm but never done it on anything before so curious. Could a slow filling loop case a problem or something? Tbh if it doesn't cause. A problem I would rather it take more time as I can be more careful.
