Android Phone Boasts 15-Day Battery Life
Be good if true, but realistically 3 days of reasonably heavy use.
Is this some cheap Chinese brand though? As their batteries are never upto what is claimed.
And how are they fitting that much in a fairly normal sized phone. If it was using a newer energy dense battery, then it would be far more expensive.
Is the MediaTek MT6735 really slow but efficient?
Low spec processor and low resolution screen x big battery = long battery life.
Incidentally I always get 3 days out of my Vodafone smart ultra 6
Looks quite big and chunky though even assuming it was i.e. Samsung A plus grade cells doesn't look big enough for more than about 8000mah (probably more like 6000) actual battery capability max not the 10,000 claimed.
Like I said in another thread about LED torches - Chines Lumens does not equal British Lumens and it's probably the same for battery capacity.
I have a 10,000 mah power bank which you would not want to carry around as a phone.
Yeah definitely - was playing with a load of 18650 batteries the other day - the good brand ones like Panasonic, etc. were rated for 2200-2800mAh and actual measured capacity was often a little above that - the cheap "Chinese" brands were mostly rated 2700-4000mAh and I don't think a single one was over 1800 measured some of them as little as 550.
My tablet has a IIRC 5440mAh (good grade) battery that is literally the same size as my Galaxy Note 1 phone so you'd be looking at around 6x3x0.8 inch of space just taken up by the battery assuming standard voltage for a Li-ion phone battery.
