http://forums.anandtech.com/showthread.php?t=2457508Example:
GTA 5
[email protected]
R9 390x@1140/6200
With Overlay vs. Without
0:11-0:12 mark (+9% to +11%)
44 fps vs. 48 fps
45 fps vs. 50 fps
45 fps vs. 49 fps
46 fps vs. 50 fps
0:24 mark (+14 to +16%)
44 fps vs. 51 fps
43 fps vs. 50 fps
42 fps vs. 48 fps
Since most review sites do not show or explain how they test games, this is a very important point. Some of these differences are huge, amounting to moving up a full tier in GPU price bracket such as from a $280 R9 390 to a $380 R9 390X (or competing brand's product).
We cannot assume that all GPUs will react so negatively to the MSI AB overlay, so it seems best to test all games without it for accurate bench-marking.
This is actually a well known issue in many games but I decided to bring it up since it was a topic explored again.
BF3:
"So after much testing today, i think ive pinpointed what was causing the FPS drops/cpu lag while playing BF3 after the CQ release.
Allot of you seem to be posting what your fps is etc. And how much its dropping and all that jazz. Well if you're like me you were probably using a 3rd party program that displayed your FPS on screen such as
MSI Afterburner
EVGA Precision
Fraps
The list goes on. What appears to be happening is the OSD (On Screen Display) part of those programs is conflicting with BF3, which in turn is causing your fps drops."
or on our forum"]Battlefield 3 on our forum:
"I was suprised yesterday when i accidentally booted BF 3 without them, and i noticed more smoother gameplay.
I enabled the perf overlay and the latency on both the cpu and gpu were booth pretty consistent, where as ussualy i would get weird cpu spikes every few seconds."
Borderlands 2:
"So I opened msi ab. (I didn't touch any of the clock rates) I was trying to use it to have the overlay in my games. I then set all my settings and tested the overlay in borderlands 2. Worked well...
It then told me I was getting 20fps, it was really laggy. I closed ab and everything and opened fraps to see fps. Still 15-20fps. I got a bit scared and restarted my pc. I opened borderlands 2 and got 150fps."
Far Cry 2:
"I am always running AfterBurner in the background so I can monitor my GPU Usage/temps and framerate while gaming.
I bought another 6850 the other day and am now running in crossfire. This afternoon I decided to do some Far Cry 2 benchmarks to see how it performed.
My framerate dropped as low as 60 and the average was about 100. I knew I should have been getting higher than that with the settings I had selected.
First thing I did was exit AfterBurner and I noticed an immediate difference. Framerate didn't drop below 100 and the average was about 150.
Is it normal for AfterBurner to hurt FPS this much? Does anyone know of a similar program I can use to monitor my GPU Usage/temps and framerate in-game?
Cheers."
Same link from above by another poster:
"I have this issue with some games (Far Cry2, F1 2010), but not all."
Also,
"msi ab is causing my games to microstutter and I don't know how to fix it. If I don't start ab before my games, games run smooth. However if I start ab to monitor my cpu temps, the frame rate starts dipping. I'm experiencing it while the osd is active only on origin. I searched the bowels of the internet for a solution. Nothing.
On steam games, it runs flawless in enabled. In titanfall and battlefield 4 stutters. I cannot monitor my temps and frame rate. Every 12 secs or so a stutter drops to anywhere from 24fps to 40 fps drops. I'm currently on a 720 display maxed out on a 970."
http://www.gameplayinside.com/optimize/how-to-check-your-frame-rate-and-gpu-usage-in-any-game/
I am not saying this is a typical behavior in all games or even on the same GPUs or even the games I mentioned for everyone, but it's definitely documented online to know it exists.
Also, Joker has mentioned it various times when he finds a game whose performance stutters/FPS drop with MS AB overlay.
The proposed solution in games that suffer from this is:
"In OSD menu, add the game exe with the huge + sign in the bottom. Then just choose the exe from the list and choose "application detection level" to none or just change "On-Screen Display Support" to off. Ask again if you dont understand.
Hope it helps. Only downside is that you wont get any OSD info on screen, and wont get fps measurments on the MSI-AB Hardware Monitor. But you can use Fraps to check if youre FPS is any higher. This doesnt work with all games, but it does work in some games that dont like the OSD. Also disable the exe from D3Doverrider as well, same way there as on MSI-AB OSD Server."
http://forums.guru3d.com/showpost.php?p=3994303&postcount=17
. If you tracked my eyes when playing a game I bet every few seconds they dart to the top left where the fps counter is. Silly really.
