** PHANTEKS ENTHOO PRO M - ACRYLIC SIDE WINDOW EDITION ENABLED **
OcUK Staff
26 Nov 2014
Stoke
Phanteks have the right idea, take one of their best value gaming cases and make it even more appealing with the addition of a full acrylic side window. This results in a stunning way of showing off your build for a small price premium over the regular Pro M chassis. Phanteks have also thrown in another 14cm front fan compared to the regular Pro M model for even better value. We had a sample on our i56 stand over the weekend and it got a lot of good feedback. Stock is due around mid/end of January and the first lot will be limited so preorder now to avoid disappointment!
Phanteks Enthoo Pro M Window Edition - Full Acrylic Side Window @ £69.95 inc VAT
Phanteks’ new Enthoo Pro M variant will now include a full acrylic side panel. System builders and watercooling enthusiasts can now showcase their build.
The ENTHOO PRO M focuses on delivering great design without compromising price. Water-cooling builds will be a simple task with the help of our innovative radiator bracket and pump mounting locations. Whether you are a system builder or water-cooling enthusiast, the PRO M will give you unlimited possibilities.
Enthoo Pro M includes 1 x 140mm fan in the rear and front. Ability to upgrade to additional fans is possible. All fans included are Phanteks’ new redesigned and better performing SP series fans.
FEATURES
- Brushed aluminum look
- Clean interior - Hidden PSU and HDD’s
- Optimal airflow - Direct airflow to CPU / GPU
- Comes with 2 Phanteks premium fans - 1x PH-F140SP in front/rear (140mm)
- 3 different installation areas for radiators (120mm or 140mm form factor).
- Reservoir mounting locations
- 1x Drop-N-Lock SSD brackets included
- Removable HDD cage for installation of long PSU’s (>180mm) / waterpump
- Equipped with removable dustfilters (1x front, 1x bottom, 1x top magnetic)
- Clean cable management using Phanteks' preinstalled Hoop-N-Loop cable ties
- Removable optical drive cage
SPECIFICATIONS
- Dimension: 235 mm x 480 mm x 500 mm (W x H x D), 9.25 in x 18.9 in x 19.7 in
- Colour: Black
- Form Factor: Midtower Chassis
- Material(s): Plastic Exterior, Steel Chassis, Acrylic Side Window
- Motherboard Support: E-ATX *(up to 264mm wide), ATX, Micro ATX, Mini ITX
- Front I/O: 2x USB 3.0, Mic, Headphone, Reset
- Side Window: Yes
- Expansion slots: 7
- Internal 3.5": 8x (2x included)
- Internal 2.5" (dedicated): 3x (1x included)
- Cooling: 120mm Fan - Front: 2x (3x without ODD Cage), Top: 3x, Rear: 1x
- Cooling: 140mm Fan - Front 2x (1 included), Top: 2x, Rear: 1x (1 included)
- Liquid Cooling: 120mm Radiator - Front: Up to 360mm, Top: Up to 360mm, Rear: 120mm
- Liquid Cooling: 140mm Radiator - Front: Up to 280mm, Top, Up to 280mm, Rear: 140mm
- Graphic card Clearance: 420 mm (16.54 in) No HDD brackets, 300 mm (11.8 in) HDD brackets installed
- PSU Clearance: 318 mm (12.5 in)
- CPU cooler Clearance: 194 mm (7.6 in)
- Cable management: 35 mm (1.38 in)
- Memory clearance (motherboard - fan): 120mm: 68 mm (2.68 in), 140mm: 48 mm (1.89 in)
- Package Dimension: 315 mm x 545 mm x 585 mm (WxHxD)
- Net Weight: 7.4 kg (15.4 lbs)
- Gross Weight: 9.0 kg (19.8 lbs)
- Warranty: 5 Years
Only £69.95 inc VAT.
ORDER NOW
Will there be a acrylic side window for their other cases too? That would look good on my Evolv ATX case.
I'm happy to ask the question!
Not convinced by that, could end up looking like the 600T did with a full acrylic window. I would prefer to see a slightly bigger window but not a full window for the micro version.
Side note, I actually think the window on the Evolv is a good size as it covers the PSU from being seen as well as the blanking plate used towards the front - but a slightly bigger window would be nice :)
Sorry to disagree with you both but I wouldn't buy a case without a 5.25" bay as that's where my fan controller goes.
Yes, that's actually the better reason to have a 5.25" bay than an optical drive these days. As I have the Evolv, the PWM fan hub works pretty well once you've set it up so no 5.25" needed for me :)
As you can see it doesn't here. The Enthoo pro m has a very similar lay out to the Evolv atx so it should look good.
The specs on this case are almost exact as the Evolv. I might just get this case for the windows and the 5.25 drive which I might need for fan controller. tbh though I'll more then likely just stay with the Evolv ATX. I can only hope Phanteks at least give us the option if we want clear panel or not?
Have to say I quite like this one.
Good to see the back of the 5.25" drives, I'm looking at a full WC setup in the new year & a new case to go along with it to replace my 650D
