I've been fighting the upgrade itch for a while now. Finally given in an going to a 980Ti. I was looking at the Inno3d stuff for price, clock and warranty length. There's an X3 and an X4. The X4 has an extra fan and a heat pipe. Both seem to be compatible with EK full cover blocks but EK's configurator shows the top fan and heat pipe left on. If I'm going to convert to water cooling I'd want to remove the 50mm fan. Will it whinge if I do? Does the heatpipe have any benefit or do I need to strip it off anyway and hence might as well go for the slightly cheaper X3?
Thanks guys.
Thanks guys.
