Em...Increased Voltage and temps have gone down...
OK just ran some tests. In stress testing 1.22v (as you would expect) actually occasionally spikes slightly higher temps than 1.21v. But last night, in game for hours, 1.22v was defo 3 degrees cooler than 1.21v. Meh. Not a problem just odd.
Yeah, as long as they are safe I wouldn't worry about it.
The difference could be due to anything or a combination of things you wouldn't have noticed, like a small drop in room temperature.
Do you know what your load line calibration is set to? It might be that at 1.21v, to meet the demands of the CPU, LLC was pushing the voltage higher than that, but at 1.22 it's stable and LLC isn't increasing it as much?
0.01v is such a minor increase in voltage and 3C is within margin of error for CPU temps.
I've always found cpu temps to be all over the place with a range of 10C between cores and temps changing a couple of degrees every second. Plus the lower the temp the less accurate the measurement as the temp probes only know when the CPU is to hot (around 100C) and the software uses an algorithm to work out the current temp.
