- 16 Nov 2011
I have an old laptop with Windows 7 on, when I try and upgrade to Windows 10 it says that the bios is not supported. Is there a quite way to force the update?
Tried using the media tool?: https://www.microsoft.com/en-gb/software-download/windows10
If you can't upgrade from that, then create a bootable USB/disk with the ISO from the media tool and boot from that, you can use the Windows 7 key to activate it.
I know there are ways to do it, I just wanted to know if there was an easy way that didn't require any effort. I will try the media tool, if that doesn't work I will just create a bootable USB.
The media creation tool will give you a bootable USB, it's the same thing.
Your CPU isn't compatible, whichever method you use Windows Setup will check the the minimum requirements are met.
I can upload a WinPE ISO with ImageX and the Windows 10 WIM with instructions to Google Drive if you want. Let me know.
