Inno3d 980Ti iChill Help - LED Not Changing on Cooler under load
27 Apr 2004
Andover
Hi All,
I've had a Google and cant seem to find an answer.
On my Inno3d iChill Geforce GTX 980Ti, the Accelero cooler stays blue under load, I'm under the impression it should turn Red?
Appreciate any advice/help from other owners of the card.
Cheers,
Sean
There should be some software for it I'm guessing.
My gigabyte G1 needs to run there utility to change the colour of the card so I guess other manufacturers do the same.
I have a MSI card, just pointing you there :) Have a play around with it, also your card should have software with it for example MSI has afterburner which has like a gazillion settings in it
I'd try and hit up inno3d's support and see what they say. but for something like that 99.9% sure you need software for it installed; MSI cards; my ih80 cooler :)
Thanks chaps, I will give them a message.
Off topic.... the 980Ti is quite an improvement from my 670... :cool: Seriously awesome card.
What temps are you reaching? I have 2 of these and they seem to be directly tied to the GPU fan speed, not the actual load as advertised ( although it usually equates the same thing).
I have the little fan set to 100% all the time in Afterburner and it immediately changes my led to red so if there is a particular color you are after, experiment with different %, but this might compromise cooling.
The Nvidia led tool does not work on this AFAIK.
MSI Afterburner Fan speed fixed it!
Thanks dude.
Idle temps are 30c
Under load in CS/LoL - 45-50c
Under load in Just Cause 3 - 80c!
